1992 60tle unhooked wires... other than that A ok
Tcla5988
okay so took it out last week it ran fine wouldnt get on a plane. noticed the middle carb was not getting as much fuel as other two. so got it home removed middle carb and main jet was halfway clogged. i think that was the speed issue/plane. it ran great except 3/4 and up throttle. the vro is bypassed and wires are cut and taped on harness side as u can see in the picture.(above red power plug). the wires in question are the three in my hand. a tan and two black. ive looked around and cant seem to find three plugs that match or fit it. only found one male adapter attached to a green wire that seems to lead down to the tilt/trim or something. these wires came unhooked from a PO. thanks guys and any input is awsome. 1992 e60tlene evinrude
the boat has a trim gauge on it and if i hook up the tan wire to a positive feed, the alarm will go off constantly...
