jakerska
Thread starter- Joined
- Sep 24, 2012
- 5
I have a 1992 Mercury 60hp on my pontoon. 0D112775 serial number. Has a red stator. Starts and runs great. Charges a little too well also. Consistently has the voltage gauge pegged. Checked with a different voltage meter, puts out around 17 volts. Being a pontoon, there aren't many accessories being ran to use up the voltage being cranked out. So I figured it would be worth replacing the voltage regulator. Went on ***************** and entered in my serial #. Showed a voltage regulator in the schematic so I purchased an aftermarket one. I was a little confused as I had replaced the rectifier one time in that motor years ago when it was not charging, and I didn't remember seeing an item looking like a voltage regulator under the panel. But I had confidence as I had entered my specific serial number and ordered it (from a separate source). Got in the water to put it in, got things taken apart, and a rectifier is exactly where the regulator would go. I have read many blogs about this and many people have problems with newer AGM and maintenance free batteries. I put a new conventional battery in it last year, and for kicks I took the starting marine battery out of my fishing boat and put in in the pontoon to try. Same outcome. 17-18 volts.
So here is my question: Is it possible to upgrade this system from a rectifier putting out a constant charge or upgrade to a voltage regulator. By the time I pay the restocking fee on the regulator and shipping back, returning it doesn't seem to make much sense. I would prefer not cooking my starting battery putting around the lake. Like I mentioned, I have read through many blogs on this, although I haven't seen anyone change from a rectifier to a regulator. Thank you in advance for you time!!!
