buckeye_sean
Thread starter- Joined
- Jun 2, 2004
- 129
Hi guys, thinking of buying a used fishing boat with a 1992 50hp Force with tilt & trim. (Boat is 1991 16' Spectrum V aluminum.) Boat is in excellent condition, but I'm a little leary of the Force outboard. (Heard a lot of general comments about staying away from Force engines since they are discontinued.) Owner is 2nd owner of boat, and while he never had any problems with the motor itself, he said he has had the lower unit rebuilt once right after he bought it, and then just 3 years ago replaced the whole lower unit. I guess it was constantly leaking at the seals. Is this a common problem with Force outboards?
Also, while I know it's tricky to evaluate used engines without an hour meter - how many hours do you think I should "assume" is on it. (50 per year...100 per year...more?) How much do you think the motor by itself is worth? I'm trying to come up with a reasonable offer, since his asking price is a bit high.
Just curious what you guys think about this motor, and if I should bother with it at all. (I do like the boat though!)
