1992 40 horse Johnson
gimli1977
Hello
I'm getting ready to start up my outboard after having rebuilt it, and I can't remember where the negative coming from the battery is supposed to hook up to on the motor. Anyone know?
Thanks a lot
JB
Re: 1992 40 horse Johnson
Bolts to the engine block, just like the pic in your Manual, Gimli.
tashasdaddy
remember double the oil during breakin. it will smoke, that is better than ruining a rebuild.
gimli1977
Thanks for the replies. I did find the grounding point on the block..my Johnson manual never did say exactly where it landed that i could find...just always had it running to ground.
I am running 25:1 on the startup. I checked my compression yesterday and had 135 on both cylinders, but I can't get it to idle without goosing the carbs slightly. I'm going to read through some of the other postings on here and see if I can get some further info. My manual is talking about timing it with a test prop and a lot of equipment I do not have.
Thanks again!!
