1992 2502 Bayliner Trophy
padirocco
Looking for specific information from manufactrer on the weight of this boat, looking for a trailer. Any info would be helpful.
Thank you,
Pat
apache61
Re: 1992 2502 Bayliner Trophy
Got this info from here on iboats hope it helps
1992 2502
The 1992, 2502 is a 24.58 foot outboard boat. The weight of the boat is 4765 lbs. which does not include passengers, aftermarket boating accessories, or fuel. The max rated horsepower of this boat, as listed by the manufacturer, (according to records we have) is 350 hp . If you do not have the manual for your engine then we highly recommend that you get one as repowering is costly and it takes you off of the water. When repowering, it is best to verify this information for the sake of safety and to ensure that your insurance company will cover you.
While this sportsfisherman does have a hull made of fiberglass, it is beneficial to keep the boat clean and dry by covering it properly while not in use. Good maintenance and care can help your vessel stay in good condition and have a higher value at resale. Applicable engine information has been included below since a boat needs reliable power.
Information on this page is provided to you as a free service of iboats.com. Because this information has come from many sources we can not guarantee its accuracy. Even if this information is the same as the original factory specs, boats are sometimes modified. Thus, for safety and other reasons, it is a good idea to verify information here to make sure it matches up with your boat. For additional information, we recommend the iboats forums and a boating safety course.
Engine Information:
Boat Max HP : 350 hp
Monterey10
Regarding trailers, aluminum is popular these days. AB trailers in Los Angeles is popular. There are more MFGs on the East coast, so it depends where you live. The good news is that the 2502 is common enough that most MFGs know the hull shape and can get it to you.
