This motor is a pain in the butt to start when cold. Saturday, I pulled the boat out to get it ready to take the kids out on Sunday. I had not started it in a few months and finally had to pull the air box off and put my hands over the carbs to get it to fire. Once it fired it started. I was told when I had it in to be serviced that the "Choke Solenoid" needs to be replaced.
My procedures for starting it is as followed.
1. Pump primer bulb until it is really hard.
2. turn key over and try to crank it.
I DO NOT open the throttle up on the engine as this does nothing but allow more air to get in, not choke it.
As I stated, I had to pull the air box off of the LEFT side (sitting in front of the motor, oil tank on your right, etc) and cover the carbs to "choke" the engine. Once I did this motor fired and I pulled my hands away and you could EASILY see the fuel in the carbs. I put the air box back on and it fires right up.
I was told that the "primer pump" needs to be replaced? Suggestions?
Rodbolt, CONGRATULATIONS on your recent marriage, good luck on your outing to Orlando and your upcoming class. Let me know what you think! I do not want to spray ether in the engine as this cannot possibly be a good thing for the engine.
Thanks,
Stephen
Thanks,
Stephen
