1991 wellcraft rebuild
Locomono
Hey all. I'm about to begin pretty much what Friscoboater did with his sea ray 220 br. But I'm wanting to upgrade from 5.7 with alpha outdrive to 7.4 with bravo outdrive. Any advice on that? And will I need to take the cap off to get to everything?
alldodge
Welcome
There are a lot of different wellcraft's might want to tell us which one?
And a rebuild thread without pics is worthless (n)
tpenfield
As stated, some pictures will help. You probably have quite a bit of work ahead of you before fiddling with the engine/outdrive. You probably want to understand if there are any horsepower limits to the Wellcraft model that you have.
While you are rebuilding the boat, you can keep an eye out for 7.4 engines and Bravo outdrives, transom assemblies.
Got a budget in mind for all of this?
As for the cap . . . the pictures would help. But usually I/O configurations can be done without removing the cap. It sort of depends how much of the boat (cockpit/sole) is part of the cap. 1991 was during the transition of boat design where the cockpit/sole became part of the cap and not part of the hull. . . basically 2-piece construction.
alldodge
Online pics give me the impression transom should be able to be done without removing cap. These are just exterior pics
