1991 regal velocity pedastal seat mounting
panamacitymustang
So I finished putting my deck down and I forgot to place the bottom pedastal brackets under the deck. Now I need some advice on how to mount my seats with out cutting a big hole in my deck. Any advice would be greatly appreciated.
Ayuh,.... 'n what sorta seat bases,..??
panamacitymustang
No Title
The deck is 1/2. This type of pedestal with the ring that goes under the deck
Woodonglass
I'd do something like this...
Put Stainless T-Nuts in underside then glue and glass the pedestal to the deck. Maybe only make it 3/4" high instead of 1 1/2" like this one. By widening the base it puts less flex on your deck. If it ever had a problem, it's easy to replace.;)
panamacitymustang
Thank you I was thinking of something similar. What could be used to fill the t-nut so the epoxy won't fill up the t-nuts. While glass it in. Play dough mybe.
panamacitymustang
I started mine a couple years ago. Then shattered my ankle and that put me out for around a year. Good luck to you as well.
Mark72233
Ensign
Hope the ankle is healing. I saw you had a 1991 Regal and I bought a 1991 Regal donor boat for the engine and need to get rid of the boat and trailer but I looked your Velocity Model up on Google and not the same boat. That is a cool looking boat. What type and size engine does it have.
