1991 Playcraft pontoon restoration
warddog
I recently bought this pontoon as a project and am in the process of removing everything from the deck so I can replace plywood and carpeting. All the furniture as well as the helm console were totally trashed but had the helm and the steering wheel that I got out of the console. How do I remove thew steering cable from this steering mechanism as it appears different than the ones I have looked at in online videos? This mechanism has the cable coming into it but nothing coming out as I have seen from others.
warddog
Undo the motor end.
I still have to get the cable out of the steering box, which is my question. Removing the motor end isn't my problem.
if its a rack and pinion helm, you dont get the cable out. you get a whole rack and cable assembly
warddog
So you are saying that in order to get the steering cable out of the floor to replace the steering console, I have to remove it from the motor end and pull it out through the floor from the helm end?
If you have a rack and pinion helm. The rack is crimped to the cable sheath.
warddog
I am new to boats and have no clue of what it is. I'm going to see if I can post pictures for those much brighter than I am on these things. This is the front and back. Cable comes into the unit at the top and doesn't exit it as the unit is closed. I have more pics if needed. Thank you for your inpout.
That is a rotary helm. You may be able to separate the helm from the cable by disassembling the helm
redneck joe
For just getting started on the whole thing i would disconnect at motor and pull back up to helm and remove helm all at once, which you will be doing anyway. Work on the steering as you can.
warddog
disconnected the steering cable from the motor BUT cannot get it out. The steering console was shot so I've removed the helm from it and it is sitting intact on the floor. I've pulled as much cable through the floor so I've got plenty of room at the motor end to pull the cable out BUT cannot budge the cable out of the steering sleeve on the motor.
warddog
Both nuts are loose? Maybe semi lightly tap with hammer?
I removed the nut holding the steering cable into the tube on one side and the steering arm from the motor to it on the other side. Pulled it out about 4-5 inches and can't budge from there. I have sprayed WD40 and PB blaster into the tube around the cable but makes no difference. I've tapped the steering arm end with a hammer and a block of wood and still can't budge the cable any further out.
I would simply cut the cable off a bit outside the tilt tube, then use a brass drift and a 5# fist maul and point the remaining bits out. Then clean up the inside of the tilt tube with a wheel cylinder hone.....Then get a new cable and helm
warddog
No need to cut the cable as I did get it out of the helm, so it is lying flat out from the tilt tube. I suspect the cable has the steering attachment as part of it and that entire thing has to be driven out of the tube? Been pounding it with a 3# maul and a block of native oak and so far can't move it out any further. It is a straight shot out now.
redneck joe
So s ott, help me here. I've only pulled two steering cables in my life and both were oldish, both needed some stern wiggling, but why / how can the move from point a to b but not to z?
warddog
FINALLY got the steering cable out from the steering tube. Scott was correct as it took a big hammer and a drift smacking it pretty hard to get it out. I had been spraying it down with PB Blaster for about three days and yesterday I got it out. Funny the cable didn't appear too bad or corroded. I'll ream out the tube with something when I get to that. Right now I'm focusing on getting the carpeting replaced. Thank you to all who responded to my problem.
