Re: 1991 mercruiser alpha 1 problem
The problem is that the motor support rotted and the front of the engine dropped down about 1 1/2 to 2 inches.
That has to be the worst case of rot in a 91 boat I have heard of, that or Glastron forgot to fiberglass the stringers. I would hate to even think what shape the transom and every other piece of wood in that boat is like. Unless you are into replacing the stringer, and the transom (HUGE DIRTY JOB) it's time to keep looking.
When it did the boat made a whirring sound (quoted from owner) and the prop stopped turning.
If you really want to know what that noise was, my guess is it was a lot more that a whir. the coupler probably disassembled itself, when the engine dropped that much, I would wonder what else between the engine and the inner transom shield broke, maybe a mount, perhaps an exhaust Y. who knows. IF you needed an engine and drive, that boat MIGHT be worth something. 100 bucks tops. if the engine doesn't have a cracked block from not being winterized.
