catfishindude
Thread starter- Joined
- Mar 28, 2010
- 3
Someone please help, I bought a used pontoon beginning of last season. The motor ran good ( 91 johnson 70hp ). When tried to bring back to life after winter, it will not start. The motor was changed to pre-mix by previous owner. When I pulled plugs they all three were wet and smelled of fuel. I tested for spark and it has no spark on any cylinder. I do not know if this has anything to do with it but when it did run the tach did not work and the volt meter acted funny from time to time. I also did compression test it is at 115 on all three give or take one or two. It was outside so motor temp would be around 50 F. Is this a good number?
Thank for any and all help.
