j_k_bisson
- Oct 6, 2010
- 1,082
For those that followed my other two projects, this is one of this winters projects. I always get into a couple every winter due to having tons of time out in the garage after the kids go to bed and the wife is at work.
The plan is to restore/rebuild this 1991 Force 120 hp fresh water motor that came with my 1991 Bayliner Trophy and sell it to the neightbour. The #3 cylinder is scored badly and requires boring. This is from the common porblem with these motors of a ring braking and a piece flying around in the cylinder. All other 3 cylinders are mint. So the plan is to pull the sleeve and put a new on in at a cost of $200 total for the sleeve and work. Buy a pistion kit for the cylinder. Then hone and re-ring the other three cylinders. Making this a rebuilt short block. Basic plan and one I think I can get away with for under $600 total without labour. Thats always free. Most of the parts are going to be coming off ebay, love discount pricing anywhere I can get it.
One other thing, this motor runs and runs well. Just idling it does not. The compression in the cylinders are as follows #1 135, #2 135, #3 125, #4 145. This is starting at the bottom and working up. I have taken the head off and looked at the cylinder and the only one that does have damage is the #3. Can not explain the #4 numbers being high, figure it is due to the #3 being so low. Will find out when I get it appart.
I already have all three factory service manuals for this motor, the full gasket set. All I need is the sleeve ring sets and pistion kit. I'll take my time between now and X-mass and spread out the work. I have decided to have Chip's Head and Hole Shop in Michigan do all the sleeve work as all the local marine dealers have him doe theirs. Also when I was talking with LA Sleeves they recommended him for the work as well. So three marine dealers and a sleeve supplier recommendations is good enough for me!
Here are some picks of the motor as it stand today/last night. Will probably get the cowlings, electrical, and carb's off in the next couple of days. Then the really fun parts starts this weekend. Block disassembly!
