1991 Evinrude 48 SPL, cleaning carb.
noworries79
Is this a job I can do myself? I'm always looking to save some $ and learn new things about my engine at the same time. The shop did a great job last year, but if I can do it myself, I would love to put that money towards gas for the Fall season. Thank you in advance!
noworries79
Re: 1991 Evinrude 48 SPL, cleaning carb.
No problems, but I can tell it isn't running quite as good as it used to. Maybe I am just a perfectionist and want it running 110% all the time. How often do you suggest doing the carb. cleaning? Thanks for the link too!
tashasdaddy
if seafoam is used in your fuel, carbs can go 10-15 years without cleaning. i would look at the plugs, plug wires, they deteriorate over time. if i were to check anything it would be compression. how often do you change your impeller? should be atleast every 2 years.
