SemiTufJeep
Thread starter- Joined
- Jun 11, 2009
- 3
Simptom - Pees for about 5 seconds, then just dribbles.
Changed impeller, same thing.
Tested impeller (with a drill motor & ear muffs) and it works fine.
Connected a water source to the water inlet tube (where the water pump feeds motor) and it pees for about 5 seconds, then just dribbles. Dribble turns hot after a few seconds and head temp reaches 205 within a couple minutes.
Tried back flushing (thru the pee hole), then I get a solid pee for about 5 to 7 seconds then turns to dribble. I've had motor for about 3 years changing impeller, spark plugs, gear oil every year. Could this be thermostat related. I have not change that part since I've owned it.
Thank You for your time!
