Re: 1991 Cajon 1750 Espirit bilge pump
Welcome Russty...your bilge pump should be located under the sole (floor) at the stern (rear) of the boat. If you're powered by an outboard, probably right near the transom and you should have an access hatch above it. If powered by an i/o, probably beneath the motor and will be accessed in the motor compartment. Both may be buggers to get your hands on. There are many threads in the forums for doing diagnostics to determine if your problem is electrical (bad connections) or mechanical (bad pump). One suggestion is to check that every electrical connection is bright and shiny (use sandpaper or wire brush) and that they are all tight. Also make sure your switches at the helm are clean and tight. Good Luck!
