1991 Bluefin/Spectrum 19.6 Gas tank problem
Bluefin91
Does anybody know what type of 1/2 inch ID fuel line can be used on the inside of a inboard / outboard gas tank? It is for the pickup and vent hookup. I don't know if regular fuel line will work.
GA_Boater
Are you talking about the short down line to the pickup? Is there something wrong with it? From your other thread:
fetch
Bluefin91
Yes the short line, Its cracked. I was thinking about using nitrile hose,
Watermann
Below deck you should use USCG approved fuel lines only rated J1527 low permeation.
GA_Boater
This is an internal tank hose. I'm not sure an external hose would last submerged in gasoline and the outside may deteriorate.
Can't add a pic from Bluefin's other thread to show what he's working with.
GA_Boater
That is much better if BF can find the correct size. I didn't look at sizes, but it's made for inside a tank. Thanks for finding that WM.
Watermann
Heck yeah no problem. The pic didn't come trough you posted but I can see it now, that old line looks like polyethylene.
Bluefin91
Thanks for all the responses, I did find a gas 1/2 inch id submersible hose on a e---. It is a gates Barricade hose 27342. Its actually a fuel injection hose that can be totally submersed in gas. $10 a foot. Just enough for the lengths I need. It was really hard to find a 1/2 inch ID for some reason.
