Incorrigible
Thread starter- Joined
- Jan 5, 2009
- 111
Engine is a 1991 5.7l
Issue is this: Engine quit producing full power. Tach read 4400rpm WOT in the beginning. Now reading 3600rpm MAX WOT. This is IN THE WATER and in gear while running under normal conditions. Out of gear engine will more than redline.
Have checked alignment and lower unit.
Have checked tach.
Have replaced wires/plugs/coil/ignition sensor.
Have completed compression test, spark test all cylinders.
Engine is properly timed.
SECONDARIES on the ROCHESTER 4MV carb do NOT open.... I'm guessing, but I think this is where my problem lies.
For what reason would my secondaries fail and how would I go about testing this?
Also, when holding the secondaries open, in water, in gear, engine still doesn't reach power (assuming just holding the butterflies open doesn't increase the fuel flow from the secondary full metering rods?)
Any help, or point in the right direction? Greatly appreciated.
THANKS
Have checked tach.
THANKS
