1991 40h force Johnson, need help !!!!
MATTT
I have a 40h force Johnson, and the year is 1991. A black round rubber washer, fit between the anode and the thrust hub where the propeller at got torn up. I took it to the mechanic and ask for a new part. No one seem to know what it is and what it calls. If any one out there know what I am talking about. Please, let me know. I am willing to give you more info if I miss out on any useful information.<br /><br />Thank you, in advance.
kev_79
Re: 1991 40h force Johnson, need help !!!!
Well, I am confused as to what a force johnson is. Force, the one I am thinking of was made by chryler up to 90, then Mercury took it over. Are you sure it is a force, or is that just some kind of adjective they used on the cowling? As for the rubber washer, I think I might know what you are talking about, but am not sure what it is called. If the mechanic doesn't know, I say you should get another mechanic. Maybe one with a book, b/c I am sure it is in there. Good Luck, let us know what's up.
MATTT
Hello, kev_79.<br /> I am sorry, I might say it wrong. It is a 40h oil inject outboard Johnson. When I look at the shop mannual, I don't see it either. I am confuse. I took it to an OMC parts store, and they don't seem to know what it is either. If anyone know where I can get one, please let me know.<br /><br />Thank you so much.
clanton
Give me the model number to insure the correct year. I have a set of parts books and will try to ID the part.
MATTT
Hello, Clanton <br />Sorry for taking so long to get the info. I have to drive back to the lake to get the numbers you are asking for. Anyway, the MOD NO. is J40TLE5R and the SER NO. is G02492623. It is a 40h johson out board oil injected. Please let me know what you can find.<br /><br />Thank you so much for your help.<br /><br />Mattt.
clanton
The only rubber behind the anode in the parts book, that I see is th propshaft seal.
MATTT
Hello, Clanton<br /><br />Thank you for getting back to me so quick. Well I call the shop and ask if they have the part, again they don't seem to know what that part is. It didn't show it in their shop book. You wouldn't happen to have the part number do you ? The place where I usually go to buy part is called the VAN'S SPORT CENTER. <br /><br />Thank you again.<br /><br />Mattt
clanton
I look at book again, the only thing I see behind the anode is seals, and if this is out, gear oil should be running out. Seal # 321467 takes 2.
clanton
MATTT
Hello, Clanton.<br /><br />I know the two seals which you are refering to. It has the metal casing and is use to stop the water from coming in to the gear and keep the gear oil from coming out of the lower gear. The rubber insert I am looking for is located before the anode. After the Propeller it would be the thrust hub and then the black round rubber piece fit into the anode, then next come the anode. It didn't show it in my shop book either. But it is there when I am replacing the propeller. Do you think it might came with the anode if I am purchasing the anode kit ? I am not sure, let me know.<br /><br />Thank you again.<br /><br />Mattt
clanton
You have a steel thrust washer behind the prop right? I looked again from 89 to 97 nothing.
