1991 225hp starter how to test armature
tbarker
Hi,<br /><br />First I should say I used to be in the power tool industry....<br /><br />I need to test the armature of a '91 225 starter. I don't have access to a growler, so I'll have to do it the hard way with a multimeter. The problem is I am unfamiliar with the commutator pattern, there are 4 brushes, so how do I test?<br /><br />The starter won't spin at all, even when removed and juper cables attached directly.<br /><br />The soleniod is OK, as are both batteries. I have tried shorting directly to the starter terminals, still nothing. The field (permanent magnet) has a small chunk out of it, but this shouldn't make the starter fail completely.<br /><br />It was having some trouble spionning the bendix up to the flywheel, so I suspect the armature may have a fault, breakdown of insulation perhaps?<br /><br />Great forum!<br /><br />Cheers,<br /><br />Tim
