magnumdeke
Thread starter- Joined
- Apr 13, 2010
- 626
Got a kicker along with my 150 hp. Kicker is a 1991 or two (15hp tiller) by my best guess. Tag is unreadable, I do have a serial# wrote down at work that I got off of a freeze plug, Will post tomorrow. going to rehab this motor back to new. It has good compression and spark, start switch sucks, but I did get it to work with a soak in contact cleaner, gonna have to get a new one eventually.
so I got a new kill switch as that was missing, water pump kit and a carb kit too. PO had this thing butchered up to run remotely, kill switch on transom, lawnmower throttle cable, the neutral safety linkage was broken. I will be rigging it up for remote also after getting it back to original configuration and then I will add a solenoid in the boat and an ignition switch and figure out how to actuate the choke with a RC solenoid and run the throttle with one also, ala trollmaster.
Even with the mods I will have it set up so I can remove it and use it on another boat also. First question I have is the ignition switch is obviously a high amperage switch, no solenoid on the motor. What amp switch do I need? How high are the cranking amps on this motor?
Start with that, thanks guys!
