1991 175- Pull power head to get to steering arm?
nickd
!991- 175 yammie- steering arm corroded- I have removed lower unit, stripped the remainder of the block in preperation for a good cleaning and painting. Steering arm is expectedly rough- it it worth the risk of broken block mounting bolts to remove the powerhead to get to the steering arm?
I have access to glass bead blaster if I can get that far. thanks
Block bolts can be turned with a 6" box end wrench- powerhead is comming off-
