1991 15 hp Mariner -torque/trim tab?
sjcslk
Should this motor have a torque tab? I inherited the motor. The 14' boat its on pulls hard to the right. Online research says an adjustment to the torque/trim tab above the prop fixes this, but this motor doesn't have one. It looks like there is a little plate with a screw there instead. Also, the plate is right behind the water intake. It seems like an odd place to put the water intake because its difficult to put muffs on it. If there was a torque/trim tab there, you would have to take it off each time you wanted to use muffs, i think.
