1990s suzuki dt4 4 h.p.outboard
Phil100
How do you dissassemble this unit to remove carburator. This outboard starts and runs with choke but as soon as you put the choke in and throttle it it bogs down. I've read some forums stating to clean carburator. I tried removing the carb but the housing gets in the way. Is there a way the housing separates from the engine so I can remove the carb?
