Itsnotme1988
Thread starter- Joined
- Jun 22, 2015
- 23
Not sure what year the motor is exactly...but the starter doesn't like those on a 90, but it looks like a 92. But I have no idea...anyway
I keep having an issue with air being pulled into the fuel lines. The pickup tube has been replaced, all lines from the tank to the primer bulb are new. Repalaced the primer bulb, filter housing (was used) and the filter. Changing the pickup tube helped but my dad said he was unable to force it.all the way on. The old one was loose. This helped a lot. After running it a few miles it would occasionally cough again. If I squeezed the bulb I could feel some air in it. After a bit more running it was fine. Went about 8-10;miles and it coughed 3 more times. I thought all was well until I pulled out from the dock, got passed the No Wake buoys, mashed the throttle and she coughed and died. The bulb was dry it felt. After a LOT of pumping it finally started bit was never tight. Felt like the filter was empty bit I had no tools onboard. Got it back in and pumped a lot more until I felt air bubbles then pressure again. That's when we trailer ed it and called it a day.
It is worse at higher speeds from what I've noticed.
Soooo....the plan at this point is to go back through and teflon tape all the fittings and double clamping the lines. What else should I look at? This problem has been exhausting. I know it has one cylinder that is just out of range on compression but it runs great other than.this issue and being VERY cold natured.
(Sorry that's long...trying to describe it the best I can and have very limited knowledge about boats. This is my first...)
