FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
vro fuel pump fuel hose routing any pics or diagrams?:confused found picture of vro pump showed hose routing. I had in fuel line hooked uo to wrong inlet Thanks all
I tried to make it short and simple, took carbs to rebuild lots of fuel lines to connect fuel pump vro lines should of took a picture of where they all hooked up.Some are easy to tell where.Main fuel line does it go on fuel pump or vro pump.I put it on fuel pump. pumped up turned engine over acted like its not getting gas.I guess I may of screwed up on rebuild,float adjustment?Detailed
