The boat came with 4 blade13x19 props but it only maxed at 4400 RPMs at WOT, so I got some 4 blade 13.5x15s and it does max out at 5000RPM now. If I run one engine though after 3000RPM it revs up like it's slipping and the boat doesn't pick up speed, both motors do it, just revs up to max really fast. Below 3k it is ok but it goes slow, no going on plane. I have not raised on engine to see. With both props engaged it takes off fine on a lake. Seems to have good power, 35mps max speed. With the 19s I had 38mph. I don't care about high speed as you cannot really go faster than that in SoCal waters. I have not yet tested it offshore in current. The lake was pretty choppy and current was pretty strong though. I am just worried that it is under propped with the 15s even though the RPM is at 5000 where it should be as the book has it at between 5k and 5.5k. Is this ok or should I go to 17pitch or go back to the 19s? Thanks in advance.
