Alot don't actually sit on the transom. It's more an issue of the prop being in the right height;
I need your help with my math plz if you can, anyone actually. Because of how I took off the engine, I'm unable to lower it completely as if I were to run it. So I have to do some deductive reasoning with my math. The transom once done will max out at around 2.5" nothing more. The mount measures at 3.25", so I should be safe.
The length of my bow is 19.5". The length of the mount from the top is 14.25". The length of the bottom hole to if the engine were running to the base where engine should sit in the water is 6.5" according to my measurement.
From the last hole on the mount to bottom is 1.25". So if I add 6.5" to 14.25. Gives me 20.75". Minus that to the 1.25 gives me 19.5". So if I have the engine sitting directly on the transom I will have it spot on, according to my calculations. Even if it's 1" up or down, I should be ok right? I'm trying my best here with my calculations.
