TheTaxButler
Thread starter- Joined
- Jun 29, 2019
- 9
Hello to all the the wonderful people in this forum. I am a new boat owner, having grabbed a 1990 Sea Ray BR160 off craigslist for about $350 as a project boat. I was having issues with the fuel delivery to Carb so switched over to an electric fuel pump. I KNOW the mechanical fuel pumps are more reliable and will keep the old one on hand, I guess I just like to try to make things more difficult for myself, which leads me to this post.
I have an oil pressure switch teed with the oil pressure sender. I have looked extensively at other forum posts on how to wire the pump and switch system. I have wired the pump to the switch with a 10amp fuse in between per my pumps circuit schematic. My pump is rated at 4-6psi which is what I was told is all well and good for a carb system. I have also sent a wire from the switch and INTO the purple ignition switch wire on the wiring harness. Other forum posts, especially by the venerable Don S have shown a schematic which shows to send a wire to the Starter Solenoid at the purple/yellow wire. The problem is that my Mercruiser 3.0L AlphaOne does not have a purple/yellow starter wire on Solenoid. It has the regular Red, orange and Red/Yellow wires on the Solenoid (the latter of which is in the opposite position of where Purple/yellow would be. I went ahead and attached the wire to WHERE the purple/yellow would have been on the diagram. Mistake?
When I turn the key from off, the pump does not come on but it will come on after I have tried cranking the unit. Is this correct operation? If it is not sending pressure until after I have stopped cranking, I don't see how that would help with starting or filling the carb bowl! I have read another forum with another Mercruiser that seemed to have the same setup with another post by the Venerable Don S indicating that maybe they should try using the red/yellow wire on Solenoid. Should the pump be working only when trying to crank, when I first turn the key on from "off" position or both? I can send pictures later if needed. Any help is appreciated for the beginner boater!
