Hi everyone. I'm a new boater (more or less) and new to the forum. I just picked up a 1990 SeaRay BR160 with an outboard 115 2-stroke (oil injected). For now I'll save the whole story for another time but currently I have an unexpected problem that I'm determined to solve and get this boat on the water. I'll need some of your collective intelligence to make it happen!
The engine had a real hard time "turning over" past a particular spot when I got it. After some testing, I determined that the starter was probably weak and replaced it. With this I was able to get it fired up and running. But before long it was stuck at the spot again. Yanking on a rope around the flywheel will not budge it a bit, whereas the rest of the rotation is quite easy. So I pulled out my new plugs and noticed 1 was darker and had some metal particles stuck to it. This was the same cylinder that had a significantly lower compression reading then the rest when I tested (70, 62, 85, 80 top down). So I decided to pull off the side cover to get a look at the pistons. As I suspected, 2nd from the top is busted up on the side right at the exhaust port. Don't know if the ring failed first or if there was an oil problem in that cylinder first or what. But I know the piston needs replacing. The cylinder wall looks good but I supposed it would need honing? Hopefully the rod isn't damaged.
Now I'm wondering how screwed I got here but I'm not real interested in abandoning the boat and selling it. I'm brave (probably foolishly) and willing to work work for it. I've done engine work but not hardcore internal stuff like piston replacement.
I've seen the 1 or 2 threads discussing similar topics. I'm going to check with a local machine shop tomorrow to see if they would do the replacement if I disassemble and bring the necessary parts. Any advice/tips including but not limited to necessary parts list would be great. I ordered the Seloc manual today but it looks rather disappointing so I supposed I should get the factory manual.
Thanks for any help saving my rough introduction to the boating world!
