Ok, I am currently having fuel pouring out of the front of both carbs. I did install carb kits (no floats, mine looked ok) and I checked the height of the floats as per the manual, 1" +/- 1/8". They are sitting right at 1"
Question: Is this measurement from the gasket mating surface of the carb body to the float?
I have been reading a lot of posts that are conflicting compared to this measurement.
"Turn the carb upside down, the float should be almost level/parallel with the carb body"
Any help/clarification will be appreciated.
Peter
Peter
