1990 Johnson 90HP - Float Adjustment
68Stang
Ok, I am currently having fuel pouring out of the front of both carbs. I did install carb kits (no floats, mine looked ok) and I checked the height of the floats as per the manual, 1" +/- 1/8". They are sitting right at 1"
Question: Is this measurement from the gasket mating surface of the carb body to the float?
I have been reading a lot of posts that are conflicting compared to this measurement.
"Turn the carb upside down, the float should be almost level/parallel with the carb body"
Any help/clarification will be appreciated.
Peter
interalian
Your measurement is the float drop measurement for wide-open adjustment. For height setting (valve closed), turn the carb upside down and the float body needs to be parallel to the carb body/bowl mating surface.
Edit: with the carb upside down and assembled, you should not be able to blow into the fuel inlet.
68Stang
Thanks for the clarification. Will readjust it this weekend.
Peter
interalian
Oh, and make sure you didn't put the float in upside down, and that the little horseshoe clip is around the needle valve and clipped over the arm on the float.
68Stang
Yip, I will double-check that.
Thanks
68Stang
As a followup, the floats were out of adjustment. The lower one a bit more than the upper. She runs good now and no more fuel pouring out the front.
Thanks again.
