dereck_coons
Thread starter- Joined
- Mar 13, 2011
- 20
I got a "free" boat from a friend of a friend, just about a thousand bucks into it now and got most of the bugs out. Cleaned the carbs, replaced the starter, new plugs, drained the fuel, replaced impeller, replaced lower unit lube. Its got good compression, good spark starts good, idles good when warm, shifts smooth. When running wide open it runs like a champ for about 30 seconds then suddenly seems to just bog down. If I shift into neutral it usually recovers and then operates like normal. Any one got any ideas of where to start. It kinda sounds like the fuel suddenly runs out. Yesterday a friend was riding with me and we were trolling for a while at medium speed and it started to act up and he squeezed the primer ball and it recovered normal operation quickly. Im thinking its an air leak in the fuel line or a bad fuel pump. Any other ideas, could it be a timing issue?
