1990 four winns 19
poncho
Hi i,m looking at a 1990 four winns 19 foot with a 4.3 and omc leg. this would be my first boat and it would be used mainly for skiing and playing with the family. what do you guys think? Anything in particular to look for? thanks
Quid
Re: 1990 four winns 19
Just from a bad personal experience I'll say check the transom over well for rot. With the OMC you want to make sure it shifts smoothly indicating its adjusted properly. Of course smoothness is relative...basically you dont want any grinding when shifting.
poncho
Thanks for the replie. i'll make sure to look at that
njlarry
Four winns makes a great boat but OMC is no longer in business and the drives have numerous problems that are unique-but still servicable if you can get the part. Eihter be prepared to learn all the maintance or find someone who works on old OMC. Around 1994 OMC merged with Volvo and those engines and newer are Volvo SX drives. You can not change old omc to other drives without alot of time and expense.
If you get a good deal-maybe, otherwise look for a newer model.
tysonnathan
check the entire floor for soft spots. espescially around seats and in the back around the engine. if you have a soft spot then you have rot... and not just in that one spot.
