MayTheForceStreeMeOut
Thread starter- Joined
- Mar 15, 2021
- 13
I'll start off my saying I have looked all over the internet for ideas on what's wrong here and I can't figure it out... I bought this 1990 bass scaler with 1990 Force 90hp and was just told it needed a new trim motor. I bought it off a retired Sgt. of mine so I took his word. Well the new trim motor didn't work so it's probably needs a new trim relay or solenoid or hydraulic pump but I said I'm going to make sure it starts before I spend the cash for those. So I got new plugs and put new gas in it...and the starter doesn't engage the flywheel enough to start. Next I bought a new starter solenoid and same thing, then I bought a new starter and charged the battery this made it spin the flywheel more but not enough to start it. I bought a compression gauge but it's with the engine cold but it's 60 psi on all 3 cyclinders. I also took off the the fuel lines to see if the plastic lining was coming off and couldn't find any blockages so I tightened everything back up and cleaned the battery connections and put new terminals on the cables. I just have no clue what to do next??? Take off the carb and clean it ? My battery says it's 12.74 when hooked up to a multimeter, should I run it off a little portable tank to rule out a dirty fuel tank? I drained the tank as much as I could and put a couple gallons of a new mixture in it. Any help is appreciated
