1990 Force 90
cajunman
Throttle linkage fell off. I put it back on, and it has a sever flat spot between full and half throttle. Full throttle works great, back it off a 1/2 inch and it is like it has 2 cyl. working. BTW, it just had pistons and rings put in it. Any help out there?
12Footer
Re: 1990 Force 90
Sure sounds like it might have fouled a plug. Does it act like it is missing?
cajunman
Re: 1990 Force 90
it has a idle skip but the plugs have been changed twice.....runs fine if you move the throttle back some more
12Footer
Re: 1990 Force 90
Ok. It is deifnitely timing. Where did it fall off? And has all the play been removed when you re-installed it? The least bit of play will throw spark advance so far out, that in many cases it will not run past the point it drops time.<br />readjust the spark advance to spec, and it should run fine.
cajunman
Re: 1990 Force 90
ok I will give that a try, I will let you know if it works.
cajunman
Re: 1990 Force 90
the cable fell off at the point where the screw holds it into the notched bracket, but then the adjustment on the rear was also loose and backed itself off.
