On the twin force 120hp I completely rebuilt one of the engines and the drive. I was able to successfully start and run the engine on a hose in the parking lot. As soon as I went to the lake it started but it would die in gear. Even adjusting the rpm did not help. The carbs air mix screw was adjusted at 1 and 1/8 which should be fine. So, after it started the filter was not filled with gas so I pumped the prime bulb which caused it to stall. At one point in the water the alarm went off this is all while docked, after that engine went off and it never started again. I will check compression again; water pump is new. I hope the drive is not too tight since I installed all new bearings and seals. Can the alarm trigger a no start condition, these are not computerized. This happened before in the parking lot and I thought it was the carbs, so I switched the carb as a set from one engine to the other and then it started fine in the parking lot. Even at the lake it was fine for a while when docked but would stall in gear. I am going to retest voltages, trigger is new, stator is new both CDI, the rectifier is new, I think.
At this point I need some helpful advise. The second engine is fine. Was able to cruise around the lake at 10 mph. You cannot really get more power on twin engines when one is out.
Help guys!
Help guys!
