FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
In Other News . . .
You will notice a few enchancements to the forums to make your experience better. These include: Email Notifications, Thread Previews, Thread Starter Notation, and Emoji Options on the 'Like' icon. . .
Additionally, the merchant portions of the website have been updated and are now operational. . . . Check out iBoats for all your boating gear.
Started up my engine without the kill switch engaged. Went to turn off with the key and the engine stayed running. Is this a problem with the ignition-kill button? Any help much appreciated.
it sound that your kill SW is bad if you can start with out it check the weiring to it and I had the same problem not shutting down and I installed a new ignition SW and that fixed the problem.
The kill switch grounds the CDI boxes and is usually tied through the ignition switch. It could be a loose wire or a bad ground. Get out the book and check the kill wires under the dash.
