1990 Force 120 Lean Misfire
bigmatt14
Got a 1990 Force 120 that's running lean and popping. Prior to this, I pulled the carbs, replaced carb gaskets, checked reeds, checked spark, and compression. I basically I did all the preliminary diagnostics before I arrived at this conclusion, with the help of an automotive mechanic friend.
It smooths out and runs great when carb cleaner is fed through the bottom carb. There has to be a leak somewhere behind the carbs causing this lean condition, right?
Anybody have any idea what's going on? Is this a common occurrence with these motors?
Thanks
pnwboat
Re: 1990 Force 120 Lean Misfire
What about a bad fuel pump diaphragm, or sticking one way check valve in the fuel pump? Sometimes you can squeeze the primer bulb while the engine is running which pumps more gas into the fuel bowls which will "fix" a pump that is not working well.
bigmatt14
Haven't looked into the fuel pump yet. I'll do that tomorrow and post back.
Thanks
jerryjerry05
How did you set the air screw? 1 turn out.You have good gaskets? Try spraying ether around the intake,see if it changes anything.
You check the reeds.How about a compression test.J
roscoe
Perhaps it is just running lean because the idle mixture screw is set too lean; or a small speck of debris is clogging it.
Give the mixture screw 1.5 turns out, then turn it back in 1 turn.
bigmatt14
Unfortunately, it isn't the mixture screw. Played around with that three different times with no results. I'm going to check the fuel pump and post back later today.
Thanks guys.
bigmatt14
Fuel pump checked out fine, as did the idle mixture screws. Any other ideas?
