1990 evinrude 70 hp shift disconnect
williamfw57
Trying to remove lower unit to service water pump,, where do you disconnect the shift linkage to pull the lower unit? thanx
Re: 1990 evinrude 70 hp shift disconnect
Look for the small hitch pin on the shift lever.--Pull that out and push the shift lever to the port side of the motor.-Almost no tools required.
williamfw57
OK I'll give it a rub thanks
rick001
On my 1990 60HP, I had to remove the starter, loosen the VRO pump and tilt it up out of the way to get enough room to disconnect the linkage.It is about center and under everything.
WernerF
Now that you've seen how the shift link engages, you will make it blindly next time.
Rick001----You removed the starter and all that but do you now think that was the way to do this simple job ?
boobie
Rick, you should have read post#2. Racerone is correct. Very simple to do.
williamfw57
I tried pulling the pin and pushing in on the horizontal shaft and nothing happens It seems like there is more I have to disconnect I probably DO have to pull the starter and swing the VRO out of the way. we'll see thanx tho
Pull the pin and push the crank to the port side and rotate clockwise.-------No other tools required !!
boobie
If you have the correct pin, you may have to remove the shift cable from the arm to get the arm to move to port. Did you get the pin out of the shaft ??. It's on the stbd side of the motor.
williamfw57
Going to try it again this weekend thanx I'll get back to you guys then
