1990 Evinrude 60hp VRO slow to start/no start
BigStew
I traded my motorcycle for this 20' pontoon 6 months ago. The seller took me out on the water and ran it 15 minutes, and I was good with the fact that the motor ran well. This is my first boat. The first time I ran it, I dumped the fuel tank and replaced with fresh, but I put in almost twice the required oil(the vro is gone). I now have a little bottle with measurements for different ratios on it, so I won't do that again. We've gone out about 10 times on this boat. The first trip we got 3 or 4 miles out, and the motor wouldn't catch and we ended up having to be towed in. Then I changed the plugs and we were able to have 7 or 8 trips without it refusing to start. It would be a bit of a process to start it, but it always eventually started. The last time we went out it started the first time, after quite a bit of trying. But 70 yards from the ramp it refused to start up again. We drained the battery. So I brought it home and cleaned my plugs and put it on the muffs. It started right up, and idled till I killed it. So I started wondering what the difference was, between at the lake and on the muffs. I have come to the conclusion that when the exhaust ports are submerged, the pressure is too much for the engine to overcome. I'm not a mechanic, but that is where I am in the process. I'm assuming that my compression is too low. I don't have a tester yet- I'll buy one in the next couple of days. I've read where some folks poopoo the low-end testers. I'm afraid I won't be able to buy a higher dollar one- Harbor Freight or Amazon's low end version is what will have to suffice for me. I have replaced the lower unit lube and spark plugs, but that's it. I will be buying a manual. I think I may put some Seafoam through it. Any other suggestions would be appreciated. I have an idea that maybe I can start it with the motor tilted up so that the coolant ports are submerged, but the exhaust ports are above water. Then I'll drop it down and see if it will run in gear when the exhaust ports are submerged. Is this a terrible idea? Will I put my motor in an even earlier grave by doing that, or will there be no serious consequence?
flyingscott
Rent a compression tester from an auto parts store that has a loan a tool program. You also need to do a spark test. You want to be able to start the motor in as vertical position possible. Do both tests and report back.
ondarvr
It may also have something to do with your starting method, what is your normal routine?
BigStew
I went to the parts store and borrowed their compression tester. To do the compression test, I'm planning to warm the engine on the muffs, and then pull the spark plugs and ground the plug cables. Then I'll hit the starter a few times for each cylinder. I think it said to do it in WOT. Does that just mean I push my throttle level all the way forward for the test? Stop me if I haven't put my forum-found instructions together correctly.
My normal routine is to hold the choke for about a count of three, and then crank it. I bump the choke if it starts to want to die, but sometimes it seems like it doesn't matter- it's going to die whether I let it sputter or hit the choke a bit.
BigStew
I was unable to use the throttle control to have it at WOT since it won't start like that. I guess I could have pushed down on the three ganged together arms at the carb? Regardless of that, my numbers were 107, 107, and 110. Written at each spark plug hole were the numbers 105, 105, and 110.
I'm going to go out and look for my spark tester.
Honorary Supreme Mariner
Throttle does need to open to do a compression test on that motor.----Those who say they must be open simply do not know the finer details of how these motors work !-----I am going to suggest you pull the starter apart for inspection / testing.---Compression is way too low !
BigStew
I found spark at all three plugs. I couldn't really tell you how strong of a spark it was, because it was 4pm on a bright Texas afternoon, but there was spark.
I failed to mention that when I first went to start it up on the muffs earlier to warm it for the compression test, it didn't want to run. I had to monkey with my fuel line squeeze-ball. When it was laying on it's side, it didn't want to develop much pressure. I had read that you're supposed to hold it vertically to get it to prime hard, and I did that. It started up after that.
ondarvr
​This is normal, and that's why I asked about starting procedures, you should do this before each cold start, and sometimes even more often. Holding the key pushed in until it starts, and then pushing it back in as needed is normal too.
​If you don't build pressure in the system prior to trying to start it it can take much longer to start, that's if it does start before the battery dies.
BigStew
More often than not I only squeeze the ball when it won't start. I'll start doing that every time I start it cold.
Fed
That's all wrong.
Racerone made a typo LOL!
He meant to say "Throttle does NOT need to open to do a compression test on that motor.".
.......I have an idea that maybe I can start it with the motor tilted up so that the coolant ports are submerged, but the exhaust ports are above water. Then I'll drop it down and see if it will run in gear when the exhaust ports are submerged. Is this a terrible idea?
That will help a lot, you shouldn't have to tilt it very much.
BigStew
One person has told me the compression is way too low, but when I looked it up on this forum, I see where another guy said 90psi would be the least this engine should have. So is my compression too low? Here's the link I'm referring to:
http://forums.iboats.com/forum/engi...tboards/211962-johnson-60-hp-1990-compression
Also, I'm confused about the starter suggestion. Mine seems to be spinning the motor pretty good, until I kill the battery :)
