BigStew
Thread starter- Joined
- Jun 11, 2017
- 12
I traded my motorcycle for this 20' pontoon 6 months ago. The seller took me out on the water and ran it 15 minutes, and I was good with the fact that the motor ran well. This is my first boat. The first time I ran it, I dumped the fuel tank and replaced with fresh, but I put in almost twice the required oil(the vro is gone). I now have a little bottle with measurements for different ratios on it, so I won't do that again. We've gone out about 10 times on this boat. The first trip we got 3 or 4 miles out, and the motor wouldn't catch and we ended up having to be towed in. Then I changed the plugs and we were able to have 7 or 8 trips without it refusing to start. It would be a bit of a process to start it, but it always eventually started. The last time we went out it started the first time, after quite a bit of trying. But 70 yards from the ramp it refused to start up again. We drained the battery. So I brought it home and cleaned my plugs and put it on the muffs. It started right up, and idled till I killed it. So I started wondering what the difference was, between at the lake and on the muffs. I have come to the conclusion that when the exhaust ports are submerged, the pressure is too much for the engine to overcome. I'm not a mechanic, but that is where I am in the process. I'm assuming that my compression is too low. I don't have a tester yet- I'll buy one in the next couple of days. I've read where some folks poopoo the low-end testers. I'm afraid I won't be able to buy a higher dollar one- Harbor Freight or Amazon's low end version is what will have to suffice for me. I have replaced the lower unit lube and spark plugs, but that's it. I will be buying a manual. I think I may put some Seafoam through it. Any other suggestions would be appreciated. I have an idea that maybe I can start it with the motor tilted up so that the coolant ports are submerged, but the exhaust ports are above water. Then I'll drop it down and see if it will run in gear when the exhaust ports are submerged. Is this a terrible idea? Will I put my motor in an even earlier grave by doing that, or will there be no serious consequence?
