Jkelley429
Thread starter- Joined
- Nov 9, 2020
- 12
Just picked up a 93 Tracker Pro 17 with a 1990 Evinrude 60 (VE60TLESM) on the back. Power Pack and carbs look brand new, VRO abandoned. Previous owner stated that the engine would idle fine but would die when put into gear. When I got it home I adjusted the link and sync, replaced plugs (Champion QL77JC4), replaced LU oil, and replaced the hose/valve portion of the primer solenoid (due to a broken hose fitting).
First time on the water it was idling too low but went into gear and ran fine with some low RPM hesitation. I have since raised the idle (1,000 on muffs/800 in water) and replaced the fuel pump with a non-VRO pump and replaced the fuel filter.
The last few times I have had it out it runs great at mid-full throttle but has issues below that. It will barely run below half throttle in gear (shakes bad, bogs, and hesitates) unless I briefly hit the primer on the key switch which allows it to run good for about 10 seconds and then it starts bogging again or stalls out completely. It idles and revs a little rough on the muffs/in a tank but nothing like in the water.
The following process happens when I try to get on plane:
1. Gun the throttle to 3/4+.
2. Engine bogs and drops RPM
3. Tap the primer switch 1-2 times.
4. Motor revs up and takes off like a scalded dog.
5. Runs at high RPM flawlessly (I've run it continuously at high RPM for 10-15 minutes straight with no issue.)
6. Back off the throttle to below 1/2 and it either bogs or stalls out completely.
I'm at a loss at this point as to what it could be. Compression is 100 across the board, idle mixture set at 2 turns out, plugs gapped to .03, link and sync set according to manual, fresh gas with good 2 stroke oil.
Any ideas what could be causing this? I haven't torn into the carbs as they appear to have been cleaned/replaced recently but I guess that should be my next step.
Thanks in advance.
Thanks in advance.
