fluffyducklin
Thread starter- Joined
- May 25, 2013
- 4
I was doing an engine service had water hooked up to ears. I noticed the motor was running worse the longer it ran. But would Idle fine. So I went and bought new spark plugs. I installed those and I had the same problem. Then like the idiot I am I noticed that the water was not flowing the best so I put it into the back of my mind that as soon as I was done "smoothing the engine out" I would install a new impala well then things went from bad to worse. I had my son turn off the motor. I readjusted the ears on the shaft turned the water pressure up a little. and tried a restart. It turned over then froze. Luckily ( I say that with a hopeful heart ) It wasn't a hard freeze. I took the plugs out sprayed a little lube in the cylinders and I never had to use any pressure and it was moving again. Now here we are I went and bought a whole cooling kit changed everything housing included. put it back together. It will try to start it it chugs for a second then stops. It acts like it is a fail safe mode or something. If someone could give me some insight I would be very happy.
