1990 90hp Force Flywheel
jlock
I have a 90 hp Force flywheel. The fiber ring on the underside has come un-glued. Is there a special glue I should use to re-attach this fiber ring? Sorry, after further examination, this ring is the magnet that has come un-glued. Any suggestions which glue to re-attach it?
JL
pnwboat
You can use any type of epoxy to glue it. Preferable one that is somewhat heat resistant like Devcon, JB Weld, or PC-7. Make sure you clean off any rust or residual glue from the magnet and inner circumference of the flywheel.
jerryjerry05
I use Gorilla Glue.
It expands so don't use too much.
Use a wire wheel to clean the old spot on the wheel.
Also sand the magnet clean.
You can remove some of the magnet while sanding it won't hurt.
