1990 90 hp Merc
Bigaceks1
My Cranking Battery doesn't seem to be charging when on the water trolling or otherwise,,keep getting a "LOW VOLTAGE" Display on my Depth Finder after a couple of hrs on the water with just the Depth Finder on which runs off the Cranking Battery.The Battery is a little over 3 years old and took it in twice to get it tested recently,but tested Good! Replaced the Stador in 08. Is the Stador the Alternator?
Barnacle_Bill
Re: 1990 90 hp Merc
Check the voltage at the battery with the motor running. At about 1500 RPM you should see 13-15 volts DC. If you don't test your rectifier/regulator.
