1990 60HP Tracker/Johnson Motor wont start
jvowell1
Will not start without a shot of starting fluid. once it starts you can drive it for hours. if you stop it will crank up if you imeadiatly crank it, but if you wait 5 minutes it takes a shot of fluid. Rebuilt carbs no help. Any clues?
papaterk
Re: 1990 60HP Tracker/Johnson Motor
There should be an "anti-syphon" check valve somewhere, maybe at the primer bulb if it is a removeable tank. To check a piece of clear line after the bulb should show you if it is draining back. You could also elevate the tank above the carbs to test, just temparary.
Good luck
Pop
