1990 40hp Evinrude....Help please
I recently purchased a 1990 Tracker Pro Deep 16 with a 40 hp Johnson. Three weeks ago I took it out for the first time and it ran rough and wouldn't run wide open, bogged at about 2700 rpm. I shut it of and ran it without shifting into gear and it ran fine. Then I ran it again and it took right off, 5500 rpm and almost 30 mph. Took it out tonight and it would run fine without shifting into gear, but once I shifted into gear and pushed the throttle all the way couldn't get it over 2700 rpm wide open. It starts rough and doesn't idle well either. The dealer I bought it from suggested running a can of sea foam through it. Anyone else have this issue? I really wanna get this fixed before musky season opens in 2 months. Please help!
boobie
Re: 1990 40hp Evinrude....Help please
If you just bought it from a dealer, why don't you take it back and let him fix it under warranty ??
Good idea, but the dealer is 2 hours away. I forgot to mention that the bulb does not stay hard and performance does not change if I squeeze the bulb while the motor is running. I pulled the plugs and they were dry.
62 ROYAL SCOTT
HELLO here's my 2 cents take it back to the dealer even if its 2 hours away . LET THEM DEAL WITH IT THEY KNOW ALL ABOUT IT----GOOD LUCK.
boobie
The 2 hours away may be cheaper than messing around with it yourself. Especially if you have any kind of warranty.
royal0014
Master Chief Petty Officer
Have to concur, take it back to the dealer.
Sounds like a carb issue (duh), and the Seafoam has potential to make things worse......
