1990 40 hp tiller won't run full speed
D.Harvey
changed power pack, coil, trigger coil cleaned carbs still no full speed. ground brown wire to temp sensor and motor shuts off, disconnected brown wirw from power pack still no top speeed any ideas?
Honorary Supreme Mariner
Compression test is first thing to do before spending beer tokens on parts.----You may have a lot of good used parts now.
oldboat1
"cleaned carbs" like "good spark" aren't too useful when problems indicate poss. ignition issues or carb issues. Start by posting model number to narrow things down. Then talk about methods for carb cleaning and spark testing (test of magneto output/strength).
Crosbyman
and... is this a new sudden problem or.... a slow progressive problem over time ? How is the boat underside ...crusted up or clean ?
Anything done to the engine before the problem started
Is this a sleeper you are just waking up for the new season ??
