jeff.shuler
Thread starter- Joined
- Jun 3, 2017
- 7
Where would I attach the sender wire for a tach? I tried the yellow/green stator wires and the tach worked for about 5 minutes, now it does nothing. Did I fry it from overvoltage? The other connections I made to it are as follows:
LT- To blue/yellow gauge lights wire under dash
GND- to black Ground bus
12v- to violet switched (acc) 12v at ignition switch
SEND- ???????
I attached the ignition schematic from the service manual for my particular motor. PLEASE HELP! Don't want to burn up another tach.
SEND- ???????
