Capt Randy
Thread starter- Joined
- Aug 8, 2004
- 15
I have a 1990 3.4L 250 HP Carb motor and an ongoing performance problem. As a side note, my day job consists of being an ASE Master Auto Tech, and I run a 5 tech shop. I am fairly knowlegeble in regards to mechanics, and have owned several outboards and do all my own service, including powerhead and lower unit rebuilds for the last 15 years. <br /> That being said, this motor runs funky upon hot re-starts, and sometimes stalls @ idle. To re-start hot, I must choke and open the throttles. It starts and clears and runs great at 4,000+, and will push my 24ft CC 40kts @ 5800. As I decelerate, you can hear a cylinder (or 2) quit firing and usually it (they) will kick back in, though a little rough. If I slow to idle, it may slow-troll for a minute or two, then eventually stall. Choke, throttle, re-start, over again. <br /> When this problem started I went thru the carbs, with needles and seats. New Boysen reeds. 6 new coils. New wires. Pull powerhead and check exhaust housing gaskets and housing. Fine. Bleed/balance hoses and check valve seem in order. Again, from 4,000 up it runs perfect. 3,800 and you can hear a little missing. <br /> I check the compression, with all plugs removed and WOT, and I got 30psi all holes!!! What is up with that? How can I have great power, and such low #'s? Should the throttles not be opened, as on a 4 cycle automotive engine? <br /> After reveiwing all the symtoms, can any Merc guy give me any direction, or diag??<br /> Curious in Cocoa,<br /> Randy
